Prop Selection?
Assuming starting prop is one recommended by engine manufacturer is there a table or simple method to decide on alternate prop selections?
Something that would explain or recommend alternate prop selections based on engine load and rpm. I.E. If you use a 11/7 prop then could you select a 12/6 as a larger prop with about the same engine load? Could you use a 13/6 if you had ground clearance and get similar results? Is their a formula to equate diameter and pitch to performance? Something like size times pitch. I.E. 11/7 (77) is close to 10/8 (80). 11/7 (77) is very close to 13/6 (78). |
Prop Selection?
The general rule of thumb isn't so scientific. One inch up in diameter and one inch down in pitch, and vice versa. The engine manufacturers give you a reasonable starting point in their recommendations, but the best prop for your particular flying style/airplane/engine is found with a bit of experimentation. Buy some different props (not just size, but brand too) and see which you think flys best.
prop size
1 Attachment(s)
here is a good prop chart
Prop Selection?
Thanks for the info.
I located the web site with the chart adrian attached in his reply. http://www.top-flite.com/accys/topq5000a.html |
| All times are GMT -8. The time now is 07:05 AM. |
