RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   ultimate 40 need help (https://www.rcuniverse.com/forum/beginners-85/4723018-ultimate-40-need-help.html)
danijel1971 09-07-2006 09:04 PM
Hi I was wondering if somebody has a Wing incidence angle template for this plane, when I order I didn’t received one. If is possible to be Trace on paper and email to me so i can make one Thanks. I was told i could find in earlier post a picture but no luck.Thanks
da Rock 09-08-2006 08:25 AM
RE: ultimate 40 need help
1 Attachment(s)
You make two of them obviously.
I included the ruler in the scan so you could insure that your printer is giving you a worthwhile print.
da Rock 09-08-2006 08:29 AM
BTW, they seem to be in the World Models ARF, not the cheaper ones.
The cheaper ones also don't have the stronger cabane design. It'd be worth your effort to check what's been written about that and do it. And the aileron rigging is also worth doing differently than the way all the little ARFs are done. The better way is also simpler and easier.
opjose 09-08-2006 10:49 AM
I assume that you purchased the Nitroplanes version which does NOT come with the templates.
E-mail [email protected] that you need the templates which were to be included in the kit. Also e-mail any other contacts the list and call them as well.
Tell them that you KNOW they KNOW about the need for this, and that you have communicated with people who received them from Nitroplanes... also that they should be packed in the kit.
Then don't hold your breath. It took them over six weeks to get me mine and they were warped being made of very thing wood.
Fortunately I also purchased a (now several) WM 40S Ultimates which are better versions of the same plane.
These did come with the proper templates of sufficient thickness so as not to warp... so I used them instead.
You can purchase decent templates from the WM (http://www.airborne-models.com/Index.asp) web site for 20.00 if you wish.
