RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Please help! (https://www.rcuniverse.com/forum/beginners-85/4723218-please-help.html)
R C Jack 09-07-2006 09:51 PM
Please help!
I just ordered a [link=http://www.servocity.com/html/hfs-05s_fm_rx.html]Rx[/link] and didnt see if it would be compatible with my future radio (Futaba 9c Super) Yikes! Will this work in my sig fazer?
agexpert 09-07-2006 09:54 PM
RE: Please help!
UM...maybe
Kinda depends on what you ordered...
RCKen 09-07-2006 09:55 PM
RE: Please help!
From the products description on the website. See bolded text
Hitec’s latest Micro receiver is now available individually and bundled in several new affordable flight packs and radio systems. The innovative Micro 05MS receiver features auto shift and can be operated using ANY brand of modern FM transmitter! Designed for small airplanes, the 5 channel Micro 05MS receiver uses the 5th channel as channel 6 to accommodate two aileron servos in today’s more sophisticated high performance electric aircraft.
It will work with your Futaba radio. But I would be more concerned with the fact that it says "Designed for small airplanes". I'm not sure what they mean by small, but I would think they are talking about park flyers and such. This may be a problem for you.
Ken
R C Jack 09-07-2006 09:59 PM
RE: Please help!
Well, too late now, I will return it and look for another one. Thats an OOPS too remember [:@] Any thoughts on a good 5 channel reciever that will work with my futaba 9c?
Dr1Driver 09-08-2006 05:54 AM
RE: Please help!
R C Jack,
Hitec makes several great receivers at good proces. Be sure to specify it's for a Futaba TX when you order.
Dr.1
piper_chuck 09-08-2006 06:32 AM
RE: Please help!
ORIGINAL: R C Jack
It's listed as having a 1 mile + range, which is good, but it's only a single conversion, which means it won't reject interference as well as a dual conversion. And, as ken said, it appears to be designed for park fliers. While it's got a good range, it may not have the physical strength inside to stand up to the vibrations of a glow engine.
I've got several Electron 6 receivers, they work well.
