Fuel tank alignment
Hey,
Building my first scratch built plane. Where should the centreline of the fuel tank be in relation to the carburettor? Cheers |
RE: Fuel tank alignment
The centerline of the tank should be at the same level as the high speed needle or no more than 3/8 lower. Just a rough rule of thumb here follow what your engine manual tells you and you be just fine.
I Agree And Keep It As Close To The Engine As You Can.
| All times are GMT -8. The time now is 04:43 AM. |
