RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   formula for finding CG on planes (https://www.rcuniverse.com/forum/beginners-85/474095-formula-finding-cg-planes.html)
bassmanh 01-11-2003 04:26 PM
hello all and thank you in advance for the help. i have been told that there is a formula for figuring out where the CG of a plane should be and i cant seem to find it anywhere. does anyone know what i am talking about ? and where i might be able to find it ? i have 2 planes i need to use it with before i can fly them, again thanks for your time.
mitch
tailskid 01-11-2003 08:09 PM
Yep, the rule of thumb to start with is 25%-30% of the wing chord. Of course various wings may be different, but on trainers the CG is usually around the location of the wing spars.
Jerry
Geistware 01-12-2003 01:18 PM
Re: formula for finding CG on planes
Try this link, It should help!
http://www.geistware.com/rcmodeling/cg_calc.htm
mitch
roywiglesworth 01-12-2003 01:52 PM
another old trick and it seems to work great is the string plum bob
method pick the plane up with a string one end on the crank shaft one end on the verticle stab(say thru a hinge) now take this
and hang it up by this now one piece of string like a hook in the cieling move the string back and forth until the plane is level like in flight then hang a plum bob from the hook it will piont to where the cg is surpose to be.
roy
perdo 01-13-2003 04:32 AM
CG
But always remember. " A nose heavy plane flies poorly, but a tail heavy plane flies once".
Just my Monkey wrench
Don//
