standard servos
Can you use standard size servos on a gws naro sized reciever? or would it overload it?
RE: standard servos
should be no problem
RE: standard servos
The servo power comes from the battery via a pwer bus; the only load on the receiver circutry from the servo is the signal power. The servo motor Is not powered thru the rec circuit. Hope this helps.
RE: standard servos
The statement that the servos are not powered through the receiver is not quite true. The normal setup is that the battery is connected to a bus in the receiver (all center pins connected together and all ground pins connected together) so all the power does have to go through the receiver. Depending on the thickness of the copper traces --is it 2 oz or 1 oz copper) and their width, there is a current limit. This will normally allow in excess of 5 amperes without burning out so usually no problem other than voltage drop through the connections if they get dirty or corroded. Those that use high powered servos generally set up a seperate power bus for the servos which does not pass current through the receiver.
RE: standard servos
Thanks for the great info! my regular reciever bit the dust! so i have been wanting to go flying but its been too windy for the small planes.
Thanks again. Rob |
| All times are GMT -8. The time now is 06:10 PM. |
