RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Winter flying? (https://www.rcuniverse.com/forum/beginners-85/4849862-winter-flying.html)
grayle 10-10-2006 10:10 AM
Winter flying?
I'm getting ready for winter flying, and need a glow engine for my trainer, are 2 strokes or four strokes better in the winter? My trainer donated a its engine to another plane, so I'm just wondering, a 46 AX or a Saito 56?? thanks, Grayle
bubbagates 10-10-2006 10:38 AM
RE: Winter flying?
both engine types will be fine, but if you want something to warm your hands over when they get cold, the four stroke does run a bit hotter than a two stroke :D;)
Charlie P. 10-10-2006 11:35 AM
RE: Winter flying?
http://img.photobucket.com/albums/v1...wouldhelp1.jpg
Things I find helpful:
Glomitts of Glittens - those fingerless wool or neoprene gloves with flaps that can pull over your fingers.
Towels - one for the engine and one for the transmitter - keeps the snow from lighting and melting into where it shouldn't
A flight box with plane cradle - gets it up out of the snow so the wind doesn't blow it away. Skis are much slicker than wheels. Figure twice as much room to land as when on grass . . . unless you find a deep footprint. Don't walk right out to your plane if it stalls (like when the prop hits the snow). You'll ruin the strip in a short time. Walk along the edge and cut in perpendicular, and then use the same foot holes coming out.
I have a little flange on my flight box that I can slip the transmitter handle over so I don't have to set it in the snow.
Coffee. Lots of coffee.
Worst winter mistake: I slipped a gallon size Baggie over my transmitter with holes just large enough for the sticks. Seemed clever at the time. Unfortunately, I was in trouble at take off (thought it was a cros-wind) and by the time I thought I had enough altitude I tried to get rid of the plastic. Turns out my rudder trim was full right (a 6DA with slides instead of computer toggle trims). The plastic worked up on the sticks and tipping the aileron stick to hold her level pulled the rudder out from my left thumb. Smoking hole in the snow. RATS!
hogflyer 10-10-2006 11:38 AM
RE: Winter flying?
Always keep an eye on the TX and RX batteries - in the cold weather they just don't last as long as the warmer weather.
Hogflyer
MinnFlyer 10-10-2006 12:00 PM
RE: Winter flying?
Do like I do, stay home where it's warm and build.
And BTW, between a 46AX and a Saito 56, I'll take the OS 70 Surpass (But the 46AX would be my next choice)
