RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   LT-40 Shear Web Problems (https://www.rcuniverse.com/forum/beginners-85/485833-lt-40-shear-web-problems.html)
BlackArcher101 01-16-2003 07:54 AM
I have just started construction of the left wing on the Sig LT-40.
I'm having a problem with the fit of the shear webs. They are too short to span from one rib to another. About 1/12" away from touching at each end. Would it be wise to add slivers of balsa in between the ends and the ribs to fill the gap?
If not, what do I do? It seems that they have shrunk.
Thanks for any help you can give.
EXCAP232 01-16-2003 09:34 AM
Shear Web fit
Shear webs don't need to contact the sides to do their job just so they are attached to the spar top and bottom. That being said I will add small pieces and fill the gap as it looks neater.
EXCAP232
MinnFlyer 01-16-2003 02:10 PM
Ditto, except that I wouldn't fill the gaps. The wing is going to be covered so who is going to see it?
BlackArcher101 01-16-2003 06:19 PM
Thanks for the help guys, now I can spend another sleepless night getting this thing built. :D
MinnFlyer 01-16-2003 08:06 PM
Doncha just love it?! :D
balsa brain 01-19-2003 05:25 AM
Another sleepless night getting it built and another day at work thinking about it and another sleepless night.... :o
Live Wire 01-19-2003 06:24 AM
Balance the wing before. you cover . Lot less trimming in flight. My shier stip came out on both sides. no problem .
BlackArcher101 01-19-2003 06:28 AM
Work? I wish. More like school.
Here's my space I have to work with.
http://www.lethbridgerocketry.com/wing-room1.JPG
And here's what I did with the Shear Webs
http://http://www.lethbridgerocketry.com/wing-spars.JPG
Yep, not bad for 3 nights of work.
BlackArcher101 01-19-2003 06:29 AM
Here's that second pic that didn't come through
balsa brain 01-19-2003 06:42 AM
101,i built one on a kitchen table once upon a time for that was what I had at the time.Looks like you have it covered.Just kidding. ;) When you get through,believe me,it will have been worth it.
Bill
4*60 01-19-2003 09:15 AM
Work looks better than what I can do and I have 700+ square feet. I better improve!
Build-n-flyer-RCU 01-19-2003 01:39 PM
Looks like you are doing great! The pics remind me of building planes in my bedroom at my folks house some 25 years ago. Good memories- living with the dust after the sanding steps, sleeping to the smell of drying ambroid glue and aerogloss dope...
You picked an excellent plane to build- simple, forgiving and with very good instructions. Join the wings carefully- you will probably want to find a little more room for that step to make sure that you get it right.
BlackArcher101 01-19-2003 06:06 PM
Thanks for the encouragement and tips everyone.
Build n Flyer, I'll be sure to find a nice big flat spot for that. May have to leave the rez to do so. You should see our floors, they feel uneven when walking on them. Sad part is, the building is only a year old. Here's some more pictures.
http://www.lethbridgerocketry.com/wing-room2.JPG
http://www.lethbridgerocketry.com/wing-unpinned.JPG
MinnFlyer 01-20-2003 04:14 PM
Looks like you're well on your way!
balsa brain 01-26-2003 02:29 AM
Black,one thing that you may be able to do for more building area is go to a lumber yard and get yourself a hollow core door to lay on that bed.Just make sure it is straight and flat when you buy it. ;)
Bill
EXCAP232 01-26-2003 01:43 PM
flat door
Bill
Make sure it stays flat! They do have a tendency to not remain that way.
EXCAP232
Small Fry 01-27-2003 04:43 AM
Black, I'm with you! I just finished putting th wings together, I think I'll take RC Outlaw's advice and balance it now. When it sits flat, the right wing sits at 4.25 inches, while the left wing is off the ground 3.5 inches, so i'll have to move it 3/8 to balance it out.
