Typhoon 3D - Where is the CG ???
Could you please tell me where the CG is for this plane?
I would like to fly it for the 1st time tomorrow, put it together but didn't find the CG anywhere in the manual !! Also, do you use expo/D.R. ? .. how much ? and .. what battery do you use ? I have a 20C at 2100 mAh .. would that last 15 minutes or so (not too crazy flying?) .. Thanks, AP. |
RE: Typhoon 3D - Where is the CG ???
G'day Mate.
Start at 1/3 wing chord, measured from the leading edge, that should be a good starting point. |
1/3 from the leading edge .. got it .. will try this ..
anyway .. if anyone has any measurements in cm or inches .. please post .. thanks bud .. have a great w/end .. AP. |
| All times are GMT -8. The time now is 08:07 PM. |
