RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Hinge (https://www.rcuniverse.com/forum/beginners-85/4867195-hinge.html)
Radcom 10-14-2006 02:05 PM
Hinge
Is there a difference between a CA Hinge and EZ Hinge ?
If so, what is it . I read reference to the EZ Hinge sometimes
in the threads .
Norm Nestie 10-14-2006 04:38 PM
RE: Hinge
I'm pretty sure an EZ hinge is a plastic hinge made by Sig. Unlike a CA hinge you would use epoxy with the EZ hinges.
john_s3 10-14-2006 05:58 PM
RE: Hinge
CA Hinges Are Good For Ships That Are 40 Size And Smaller.Pined Hinges Can Be Used In Any Size Ship.
Fastsky 10-15-2006 06:45 AM
RE: Hinge
Pinned hinges is the only kind I will use and as I recently learned, for pinned hinges, using a product called hinge glue is far easier to use than epoxy. :)
Dsegal 10-15-2006 08:25 AM
RE: Hinge
> Is there a difference between a CA Hinge and EZ Hinge ? <
"CA Hinge" is a generic term and "EZ Hinge" is a brand same for the same thing. These hinges are also known as flexible hinges, laminated hinges and mylar hinges.
Radcom 10-15-2006 09:52 AM
RE: Hinge
Thanks Everyone for the answers ,
Later...
ecmiller 10-15-2006 08:42 PM
RE: Hinge
If you want to fly your plane and "hope" your hinges don't fail...use CA Hinges. If you want to fly and know they won't fail...use pinned hinges.
MinnFlyer 10-16-2006 08:29 AM
RE: Hinge
And if you install your CA hinges correctly, you'll never have a failure.
Of course, if you don't trust your building skills, use those clunky old-fashioned pinned hinges.
Radcom 10-16-2006 10:24 AM
RE: Hinge
I got to jump back in and get my feet wet.
I think either one is ok ,if done correctly.
Lighter planes(smaller) I would lean more to
the CA Hinges and bigger planes both hinges
could be used.
