RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Aerobatics (https://www.rcuniverse.com/forum/beginners-85/4899079-aerobatics.html)
johnny_gr2001 10-22-2006 03:21 AM
Aerobatics
PLease, i would like to inform about the aerobatics.
What mixes i must do, what movements to the sticks must i do per aerobatic e.t.c.
Please name them and explain me the way to do them.
I would like to try aerobatics in my simulator.
Also, inform me if you have any photos or videos that name and explain the aerobatics.
alan0899 10-22-2006 04:35 AM
RE: Aerobatics
G'day Johnny,
Check out this site, I'm sure it will help a lot.
http://www.bruce.ogilvy.clara.net/te.../aero/a01.html
Geistware 10-22-2006 08:35 AM
RE: Aerobatics
Jonny,
Try my site.
http://www.geistware.com/rcmodeling/...ics/maneuvers/
Piet Le Roux 10-24-2006 04:21 AM
RE: Aerobatics
Start off by mixing out all the bad habits your plane has, if it is a pattern type plane it will have very little, if it is a stick type it will have quit a few.
I start with the roll; play with different amounts of differential until it rolls smooth and with out waging its tail.
Then I “teach” it to do flat rudder turns, most planes will tend to bank to the side you turn using rudder, so mix in reverse ailerons to keep the plain level. After you got it to do that a knife edge will not be so difficult, you may have to mix in some up or down elevator to keep the plane flying straight in a knife edge. The plain will also turn better in a stall turn with out rolling.
I also mix in throttle to elevator so that I have a bit of down elevator when I close the throttle, this helps to get straight down lines in maneuvers.
Depending on how powerful your engine is a bit of right rudder mixed with the throttle would help to keep the plane straight when climbing vertical.
Most important! The object of mixing is to make the plane fly better with les effort from your side.
Johnnie Red 10-31-2006 07:09 AM
RE: Aerobatics
There are different type of aerobatic maneuvers depends on what type of aircraft you are flying. You may perform maneuvers with a trainer airplane for instance you could practice stall turns, loops, or in scale you could practice powerdives, stallturn, rolls, loops, cubaneights, immelman's etc. But always remember the positive and negative g's that can break your plane apart. So I strongly recomend you to find an experienced fellow modeller on your flying site to help you out with these.
