RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Ohio TailWheel (https://www.rcuniverse.com/forum/beginners-85/5028388-ohio-tailwheel.html)
swixtt 11-22-2006 08:02 PM
Ohio TailWheel
1 Attachment(s)
i've looked around but couldn't find much on these tailwheels from Ohio. Anyone have any pics of their install? did you use the horns that came with it or something different.
thanks
drone pilot 11-22-2006 09:45 PM
RE: Ohio TailWheel
Depends on what airplane you're going to use it on... I have used one and it is OK, installed per instruction and no problem.
Geistware 11-22-2006 09:55 PM
RE: Ohio TailWheel
While I don't have any pictures, I attatched the springs to the rudder control horns.
It is a great aseembly but will break.
I would recommend to get the next larger size.
swixtt 11-22-2006 11:20 PM
RE: Ohio TailWheel
i'm installing it on a 72" Air Tractor running about 10lbs or so. just wondering about the ways of connecting the linkage... i'll be using a single 4-40 push rod.
