Engine Question
1. While running at low RPM's low enough so that its about to stop are hard vibrations normal? I have it set up so i can kill the throttle via radio if I need to. Will running too lean or too rich cause this?
Engine Question
What engine and prop are you using? It is possible to get some vibration at low rpm, especially in single cylinder engines. The prop balance may also have something to do with it. Let me know_bob
Engine Question
to slow the idle can cause the vibration
Engine Question
I got it, my prop had a few dings in it and therefor was outa balance.
thanks for the help guys |
| All times are GMT -8. The time now is 07:04 AM. |
