RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Noob Question (https://www.rcuniverse.com/forum/beginners-85/5184618-noob-question.html)
andrewtexas123 12-30-2006 07:48 PM
Noob Question
1 Attachment(s)
Hey,
I am new to airplanes i am a car guy. I amhaving trouble figureing out how to mount the motor. (Pics below) on to my frame it has 4 screw slots but i dont know what size it would be? Would my local homedepot carry them?
Any help is welcome
-Andrew
r/cmark42 12-30-2006 07:52 PM
RE: Noob Question
I think they are 4-40 flat head screws...your local hobby shop should carry
Missileman 12-30-2006 07:56 PM
RE: Noob Question
This is for the ones I own.
The square part above your gearbox is designed to slide onto a beam that protrudes from the front of your plane. I have seen both wood and aluminum beams used. It can be glued on or a hole drilled and a wood or sheet metal screw put in.
andrewtexas123 12-30-2006 07:56 PM
RE: Noob Question
I dont have a hobby shop that is close so will the local home depot have tham and can someone verify the size?
Missileman 12-30-2006 07:57 PM
RE: Noob Question
Yes home depot will have them. Take the motor with you to test fit.
andrewtexas123 12-30-2006 08:02 PM
RE: Noob Question
What do you guys think of doing both?
andrewtexas123 12-30-2006 08:14 PM
RE: Noob Question
One more quick question,
How do i paint balsa?
What kinda paint do i use or do i cover it?
bruce88123 12-30-2006 09:26 PM
RE: Noob Question
If electric just about any spray paint will do. Keep it light/thin.
What are you painting? The engine area or the whole plane?
andrewtexas123 12-30-2006 09:31 PM
RE: Noob Question
Whole plane so spray paint works?
ArmedZagi 12-30-2006 11:01 PM
RE: Noob Question
With the 1/16 wood you're building that plane out of I'd be worried about warping it with the moisture from the spray paint. Use some microlite covering or somthing... Dont paint it
andrewtexas123 12-30-2006 11:14 PM
RE: Noob Question
Thanks!
