RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Thin CA and Styrofoam Lining (https://www.rcuniverse.com/forum/beginners-85/5200890-thin-ca-styrofoam-lining.html)
garywi 01-02-2007 11:14 PM
Ouch. I dripped some CA on the styrofoam lining on the inside of my T-34 fuse. Destroyed it. What can I do now?
rrragmanliam 01-02-2007 11:26 PM
RE: Thin CA and Styrofoam Lining
Hi Gary,
Just cut out the damaged area and glue in a new pice of foam w/ gorilla glue. Use a pice of foam from any foam packing you may have around.
Darren
bruce88123 01-03-2007 08:39 AM
And buy foam safe CA next time.
MinnFlyer 01-03-2007 12:03 PM
No, just fill the area with some of that super-light spackling compound. It works great for repairing foam.
Ken Erickson 01-03-2007 04:41 PM
gary,
The spackle works great. Have used it for years. And get foam-safe CA.
Ken Erickson
San Antonio, TX
rrragmanliam 01-04-2007 09:56 AM
ORIGINAL: MinnFlyer
Ouch that's harsh! ;) The spackling does work great for small areas. I guess I was thinking he melted a large area from a spill.
Darren
MinnFlyer 01-04-2007 10:56 AM
I have repaired some VERY large foam areas with this stuff and it worked out great. Mind you, I do NOT like to use it as wood filler - I tried it for that when it first hit the market and I didn't like the results. But then one day I needed to do a repair to foam and I thought it might be just the thing to use. It worked GREAT! And I've been using it to repair foam ever since.
CGRetired 01-04-2007 11:05 AM
Mike.. what did you end up using as a wood filler?
Dick.
