RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Servos (https://www.rcuniverse.com/forum/beginners-85/5213859-servos.html)
English J3 piper cub 01-05-2007 08:59 AM
Servos
Hi guys,
I would like to know if all servos are the same size cause my plane has servo copartments in it and they look small? And do you get diffrent servos for rudders and elevators?
Matthew
exeter_acres 01-05-2007 09:12 AM
RE: Servos
no they aren't...
most standard servos are the same size though....
or at least really close
Which plane is it??
English J3 piper cub 01-05-2007 09:25 AM
RE: Servos
Its a J3 piper cub. Dont know what size but its wing span is 1250mm and has a .25 engine in it.
Thanks a lot
Matthew
bruce88123 01-05-2007 09:59 AM
RE: Servos
It would probalby take a "standard" size servo such as
http://www2.towerhobbies.com/cgi-bin...?&I=LXVW07&P=M
compare the sizes/specs listed and see if this or something similar will fit.
English J3 piper cub 01-05-2007 02:05 PM
RE: Servos
Thanks a lot
Matthew
Charlie P. 01-05-2007 04:30 PM
RE: Do I need a Glo-Starter
I would like to know If I need a Glo-Starter for my Thunder Tiger GP 25 ABC w/Muffler or is it just the glow plug?
The Glo-starter energizes the glo-plug. I don't have a glo-driver, preferring to use the power distribution panel on my flight box and run it off the 12v battey with a wired clip on a spring loaded reel-retractor. Never runs out of power.
If you don't use a small self-contained one you'll need one like I described, but you will need something to heat the nicrome wire in the plug to start it running.
exeter_acres 01-05-2007 04:55 PM
whoa....
did we have threads merged??
bruce88123 01-05-2007 05:01 PM
ORIGINAL: exeter_acres
whoa....
This happens now and then.
RCKen 01-05-2007 05:02 PM
RE: Servos
Exeter_acres,
No you aren't losing you mind. The original poster changed the topic of the thread, along with his original post. I have restored the thread title as well as his original post. Since this thread seems to have ran it's course now with answers given to the question, I'm going to close this thread down and lock it.
Ken
