RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Too much elevator on my Avistar? (https://www.rcuniverse.com/forum/beginners-85/525839-too-much-elevator-my-avistar.html)
nmtr13 02-01-2003 08:47 PM
Hi,
I was wonde4ring if my Avistar had too much elev. cuz it touches the rudder when i apply full up...
Is that good or bad?
Crash Master 02-01-2003 09:41 PM
Maybe its just me, but I think you got just a tab bit to much elevator on that Avistar. Spec's call for 1/4" Up & Down for low rates and 3/8" Up & 1/4" Down on high rates.
Hope this helps,
PaPa-NeGeorgeo 02-01-2003 09:44 PM
If its giving more then enough elevator try putting the servo arm on a lower arm on the elevator servo horn. Ive never flown an Avistar but it really shouldn't be touching. On my Kadet the rudder is placed far enough toward the nose that it gives way more than enough room for the elevator and rudder to move clearly without touching?
rc_boy_12 02-01-2003 11:18 PM
It should be fine if there is just a little gap between the elevator and rudder when it is pulled all the way up
