setting the controll throws with a futaba 7 cap
I dont know how to set the controll throws with my radio for my new plane. I bought the radio along with a my 2nd plane and a guy at my field set all the stuff up on the plane but i was not watching him when he did it. I am trying to finish my plane before this weekend. If you can please leave some comments.
Thanks rc-plane |
RE: setting the controll throws with a futaba 7 cap
what are you trying to do? set end points? if he has it set up then all you need to do is check all the control surfaces if they are neutral.If they are you can press and hold the upper left button model appears and scroll down to d/r exp and dial in about 50% it will fly a lot easier,and -20 exp.then if your serv. are bussing you scroll down to endpoints and ajust untill the bus. stops. good luck
Thats what I thought end points to set them but was not sure.
| All times are GMT -8. The time now is 12:36 PM. |
