leaking muffler
Hey guys,Was wondering if you could use 30 min. epoxy to seal a muffler where it goes together to keep fuel from leaking from it. Would it stand up to the heat?
RE: leaking muffler
Not sure about the epoxy, but I've used JB Weld before.
RE: leaking muffler
Clean all the fuel and oil off - then you can use high temp rtv silicone sealant.
RE: leaking muffler
you can get some Ultra Copper by Forma Gasket at an Auto parts store and thoroughly clean the joint with alcohol, put a thin coating of the UC on each surface and let it air dry a few minutes, then assemble and sit overnight.
I got this information from an extremely good authority on R/C Motors. |
| All times are GMT -8. The time now is 05:04 PM. |
