RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Servo advice for a trainer (https://www.rcuniverse.com/forum/beginners-85/5354666-servo-advice-trainer.html)
alexdeliu 02-01-2007 06:50 AM
I have a ARF trainer(LUCKY STAR 20, 1320mm wingspan, 1600g weight) and I don't know what servo are the best for it.I have 2 options:
-Futaba S3003
-Hitec HS-311
Note: I will use for this plane a Futaba transmitter with a Futaba R-136F receiver
CGRetired 02-01-2007 07:00 AM
RE: Servo advice for a trainer
Just about any standard servo should work with this plane. I use Airtronics and Spektrum (JR) servo's, all are pretty much the same, though. All the major servo manufacturers are pretty much interchangeable, but don't mix them (don't put a JR and Futaba on ailerons for instance.. if using dual aileron servo installation). Of couse, if you use only one in the center with a torque arm setup, it won't matter what you use. But, as I said, just about all standard servo's will work.
alexdeliu 02-01-2007 07:18 AM
Thanks for answer!
I will use one servo for ailerons. The problem is that I don't know what to buy:
Futaba S3003 at 12.5 EUR or Hitec HS-311 at 10 EUR. I need to buy for servos(one for ailerons, rudder, elevator and gas throle)
I think that Hitec is more robust and fiable(and a good price), but a man told me to use futaba servos if I use a futaba rc. Is there a compatibility problem?
perttime 02-01-2007 07:31 AM
I think the different brands used to have different servo connectors (plugs). I have understood that new products are all compatible.
RCKen 02-01-2007 07:48 AM
1 Attachment(s)
All servos can be used, although on some older servos you might need to switch the wires around or make slight modifications to the plug. See attached diagram.
Ken
hezik 02-01-2007 08:38 AM
I would spend a little more extra money (like 1 euro/servo) and buy futaba 3001, since it got bearings.
Both servo's you mention will do fine, but the 3001 is not much more expensive and slightly better in durability.
(Here in the Netherlands you can buy 3 3001 servo's for 35 euro).
Fastsky 02-01-2007 09:00 AM
I bought 5 Hitec servos for a new plane because they were a bit less $$. Before the plane even left the ground, one of the aileron servos started making a buzzing noise and deflected the aileron to the full down position. When I opened the case I found a cold solder joint. I resoldered the joint and it seemed to work ok but it could have cost me a new plane! I pulled the rest of the Hitecs, cut off and saved the wires, and and threw the rest away away! So now I only buy Futabas. I realize that I may have just got an "odd lemon" but I have bought over 4 dozen Futaba servos since then and have never had a problem with any of them! That speaks volumes to me. I won't go for cheaper servos again! [8D]
alexdeliu 02-01-2007 10:40 AM
Thank you very much Fastsky, that is what i was expected to hear
uetigers 02-01-2007 10:12 PM
yes, I have a new J-3-10 cub I can't determin if the servo should be flush or stick out the manual looks to show it being almost flush the servo tray has two blocks one on each end but the manual points to the servo try and not the blocks. the servo that they suggest to use is MH-48 (jsp20040) what do I need to do thank you
MikeL 02-01-2007 10:18 PM
Regardless of brand, cheap servos won't be as nice as expensive servos. That's just how it is. Each brand, however, makes fine servos.
bruce88123 02-01-2007 10:31 PM
ORIGINAL: uetigers
Can you at least give us the mfg of the plane or a link to the manual? Not much to go on here unless you want guesses. The more you give us, the better.
carrellh 02-01-2007 11:44 PM
ORIGINAL: alexdeliu
Thanks for answer!
I'd use the Hitecs and spend the other 10 euros for fuel or other needs.
My bother has 6 flyable planes, all with Hitec.
I have 4 flyable; half of my servos are Futaba, half are Hitec.
I have about 20 Hitec and 2 or 3 Futaba in the drawer waiting for planes.
The next one out of the box, regardless of price or brand, could be defective.
perttime 02-02-2007 03:07 AM
ORIGINAL: uetigers
You need to get the servo arm in a place where you can connect it to the pushrod. You also need to mount the servo (and tray) securely.
armody 02-02-2007 06:26 PM
THESE SERVOS DO HAVE BALL BEARING, I BOUGHT 4 OF THEM FOR MY 60 SIZE MID-WINGER PLANE.
Mody.
Servo Profile: Hitec HS-311
SPECIFICATIONS:
Class: Standard
Digital: No
Programmable: No
Voltage: 4.8v
General Specs:
- Bearings: Ball Bearing
- Gears: Heavy-duty resin
- 60° speed: 0.19 sec @ 4.8v
- 60° speed: 0.15 sec @ 6.0v
- Torque: 42.00 oz/in @ 4.8v
- Torque: 51.00 oz/in @ 6.0v
- 1.60 x 0.80 x 1.40 inches
- 1.50 ounces
Applications:
- Basic Trainer
- Standard Helicopter
- Sailboat
- Off-Road Car
- On-Road Car
- Power Boat
- Submarine
- Standard Airplane
- All Purpose
Street Price:
$15.55
alexdeliu 02-02-2007 07:07 PM
1 Attachment(s)
I buyed the Hitec servo, the price was better. looks great
armody 02-13-2007 05:43 PM
Alex,
Well those servos do look good, but what about the performance? have you used them so far? Im still waiting for a plane which is lying at the airport which was ordered by my friend for me, and he is so busy and kinda sluggish to get those from the airport. Well, I want your experience about those servos which naturally you like and look good. Let me know.
Safe flying
Mody
extra260bum 02-13-2007 07:19 PM
You really can't mess up with any of the name brand servos. I have 3 planes with futaba equip and 3 with hitec. I've only had trouble with one futaba and none of the hitec. In my opinion once you get into the higher torque servos hitec gives you more for your money but IMO all the standard size/torque servos are about the same
