RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Retract angles (https://www.rcuniverse.com/forum/beginners-85/5415724-retract-angles.html)
asarip75 02-13-2007 10:04 PM
Retract angles
Hi Everyone,
I know my question may sound silly, but how do you determine the angles to a retract? How do you measure it? I have come across a number of forums about retracts being at angle of 90 degrees, 100 degrees, ....etc
Thank you.
bruce88123 02-13-2007 10:22 PM
RE: Retract angles
They need to stick straight down (side-to-side). Since the bottom of the wings have varying amounts of dihedral you need to know what angle the strut will be at in relation to the bottom of the wing. 90-100 degrees.
saramos 02-14-2007 01:40 AM
RE: Retract angles
Retract angle refers to the angular movement from fully retracted to fully extended. A 100 degree retract has 10 degrees more travel than a 90 degree retract. To achieve a particular setup, you must know the angle of the retract when extended and the angle of the retract mount relative to the ground to select the proper rectract. On many models, the retract mount rails are parallel to the wing which means the angle of the wing relative to the ground is the same as the angle of the mount relative to the ground. This is not necessarily always the case. Some models may have the rails at an angle relative to the wing itself. If this is the case, it's probably to accomodate a readily available retract. Also, in many models, the angle of the retract when down may not be perfectly perpendicular to the ground. A couple of examples would be the Spitfire and the ME109.
Scott
MinnFlyer 02-14-2007 08:03 AM
RE: Retract angles
Unless it is a scale model and you're looking to keep it scale, 90ยบ retracts will almost always work fine
