charging receiver batt
I have an alpha trainer 40 with a JR 700 mah battery. Can I charge this with my superbrain 959 peak charger at .5 amps w/o hurting the batt?
RE: charging receiver batt
yes,
You could probably get away with 1 amp or 1.5 amps, but if you have the time, just go slow. |
Batteries prefer a slow charge so use the wall-wart when you can.
I usually do a 15 hr wall-wart charge the day before I fly then if need to top off at the field I use my fast charger set to 1 amp.
also the fast charger comes in handy if you unexpectedly get a chance to fly and didn't charge your RX pack. My next inverstment will be a fast charger for my TX. any suggestions. |
G'day Mate,
The best charge rate for that pack would be 70ma, that's 0.07 amps, not 0.7A which is 700ma. Slow is best, too fast & the cells will build up gas which causes them to vent, & loose electrolyte, which kills em real quick. |
So I should probably buy a second batt and have them both charged slowly if expecting alot of flight time. How many flights should I get off one 700mah batt.
G'day Mate,
It's a good idea to cycle new battery packs, talk to your mates at the field & beg or borrow a cycler, after 3 or 4 cycles with slow charging, your battery capacity should improve to about 96 to 99% of it's rated 700Mah. That should be enough with a trainer to fly all day, but use a loaded battery tester, between flights, to keep track of your battery condition. |
ORIGINAL: johntammi So I should probably buy a second batt and have them both charged slowly if expecting alot of flight time. How many flights should I get off one 700mah batt. Number of servos Type of servos - analog or digital Time with radio on but not flying - tuning, tweaking controls or "oops, I left my radio turned on".:D Drag/resistance in control systems including any stalled conditions Voltage and capacity of battery pack as well as condition of that pack Flight loads and style of flying I advise slow charging overnight whenever possible, monitor batteries at the field with ESV (or built in meters for TX), field charge if needed. |
| All times are GMT -8. The time now is 11:20 PM. |
