RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   volt watch or esv (https://www.rcuniverse.com/forum/beginners-85/5435949-volt-watch-esv.html)
johntammi 02-18-2007 09:58 AM
volt watch or esv
I presently only have one glow trainer. Does the volt watch http://www2.towerhobbies.com/cgi-bin...&I=LXHDJ2&P=ML
do a decent job monitoring your battery?
Also, it's a alpha trainer, do I need to replace plastic clevises on the alpha?
piper_chuck 02-18-2007 10:06 AM
RE: volt watch or esv
People using the voltwatch seem to be quite happy with them. I'm "frugal", so I prefer having one volt meter that can handle all my planes.
RCKen 02-18-2007 10:18 AM
No, you don't need to replace the clevises, the plastic ones that came with the plane are more than enough for your trainer.
As for your batteries, either one will do the job. I personally use the extended scale voltmeter. I check my planes before the first flight, then again after 4 flights. If I still have enough to fly then I will fly again. I'm completely comfortable that the ESV is good for my needs. But other pilots do like being able to constantly see their battery state using the voltwatch. And if it makes them comfortable then it may be worth the money to them. But for myself, I'm like Chuck, I'm cheap. I have other things to spend money on. So I would say go with what makes you comfortable.
Ken
flyinrog 02-18-2007 10:58 AM
Hey wait a minute!..I'm cheap too!..more importantly, I'm lazy and $10 is to easy to pass up for insurance on any plane...Rog
JPMacG 02-18-2007 11:23 AM
I recommend you get a loaded esv first. Then later, as you get more into the hobby, consider putting voltwatches on your planes.
bruce88123 02-18-2007 11:28 AM
One important point to watch out for when replacing clevis's or other hardware is that on most of todays ARFs and RTFs they use METRIC parts. If you dont have matching parts you may have slippage. If in doubt, replace the entire control rod including ends.
johntammi 02-18-2007 02:01 PM
The volt watch wouldn't show voltage under load, correct? Unless I work my sticks. Sounds more accurate to get the esv.
bruce88123 02-18-2007 02:10 PM
ORIGINAL: johntammi
That is true and unless you wiggled your sticks the same way every time it would be less accurate and is also influenced by control drag. The ESV should give you REPEATABLE data showing ONLY battery condition.
How much that other stuff will throw off your readings is unpredictable and that is part of the problem.
bigtim 02-18-2007 02:25 PM
I am cheap as well and use the volt watch all the time, I just have one in my flt. box and if I think my battery might be low I will pop the wing and check them wheather you have a volt meter or not you still have to open most planes to check your batterys.
most of my planes are scale so having a light strip mounted in the cock pit or on the side just does not work for me the VW are good indicators of your battery condition for a quick check item with out having to think about it .
RCKen 02-18-2007 02:32 PM
bigtim,
When using an ESV I don't have to remove the wing. I have a charge jack mounted on the side of the plane with the switch. To check the battery all I have to do is plug the ESV into the charge jack on the side of the plane.
Ken
Carlos Murphy 02-18-2007 03:14 PM
A Tower Hobbies Volt-Watch saved my GS World P-51 / Saito 180 from a bad battery cell.
I was tuning my engine in our "break-in area", ten minuets max on a full charge, removed the charger from the plane when I left the house one hour before. Shut everything down after tuning and moved to the "Hot Pit" area.
OK, time for the first flight, turn on the trans, open the hatch on the side of the fuse under the cockpit and flip the switch and out of the corner of my eye I see a red flash.... the Volt Watch in the rear of the cockpit shows low battery.
If not for the V-W I would have flown, after all I just took the plane off the charger and everything is working and the 2700 NMHD battery is only one month old, bad cell... a $10.00 V-W saved a $1000.00 plane.
YellowHawk 02-18-2007 03:18 PM
I just ordered an ESV. Hopefully I'll have it by the weekend.
bigtim 02-18-2007 04:08 PM
I try to keep my switches as small and hidden as I can those switches are a little big I do have a couple on my sport planes I agree there handy I never thought of checking the voltage through the charge jack though I always use a aileron servo lead.
Geistware 02-18-2007 04:30 PM
Plastic clevises are good.
I have a on-board volt meter on each plane.
I check it after and before each flight.
I find that many times my voltage is low after the flight and checks good after setting for 20 minutes.
ORIGINAL: johntammi
piper_chuck 02-18-2007 04:31 PM
ORIGINAL: RCKen
I AM NOT CHEAP, I'M FRUGAL! [sm=48_48.gif] [sm=punching.gif] [sm=wink_smile.gif] [sm=lol.gif]
piper_chuck 02-18-2007 04:36 PM
ORIGINAL: flyinrog
True, but when you get up to a half dozen or more planes, especially the smaller ones, the $ spent on the voltwatches represents another engine, plane, set of servos, etc. Like Ken, I check the batteries at the beginning of the day and then before every flight after I've put in 4 or so. I also cycle my batteries a few times per season to confirm that they are still performing up to spec.
ABELL 02-18-2007 04:43 PM
I'm a cheap frugal, I have voltwatches on my planes - got them from a site called batteries r us , 3 for $15.95. Don't know if they are the same quality as the ones from Tower or not but they look just like them and work fine, beats $11.00 each all to peices. 4.8v or 6.0v I can't tell them from the ones I got from Tower
Birman 02-18-2007 04:54 PM
RCKen, where is the best place to buy a ESV?
piper_chuck 02-18-2007 04:59 PM
Hobby shops and online dealers have ESVs. I buy lots of my stuff from Tower, so I have this one: http://www2.towerhobbies.com/cgi-bin...&I=LXNK81&P=ML
RCKen 02-18-2007 07:57 PM
ORIGINAL: Birman
This is the one I use. You not only get an ESV but you also have a tachometer to use too. It's nice having it all in one unit, which means one less thing to lug around in the flight box!! :D
[link]http://www.horizonhobby.com/Products/Default.aspx?ProdID=HAN111[/link]
Hope this helps
Ken
johntammi 02-18-2007 08:24 PM
Got some good info coming in, thanks. Here's another question. I'm used to rc cars, electric and glow. When your receiver batt runs low, you either see the failsafe light flashing, servos slowing down or the failsafe kicks in. On planes, a battery w/o enough juice could mean disaster.
Question> Would a charger like this do what an esv does? http://www2.towerhobbies.com/cgi-bin...&I=LXMAJ0&P=ML
I'm thinking I need to invest in a good charger/discharge cycler unit anyway to get my batts up to snuff. Is this a good charger to do what I need. All I have now is a superbrain 959 peak charger which doesn't charge slow enough and doesn't discharge.Or mention what type you use.
Thanks for your patience and help.
Birman 02-18-2007 09:57 PM
Thanks Ken. I saw that on Horizon's web site. The bad part is that I got a tachometer for Christmas from my wife. For best results I think I'd best use it. Don't want to kill the goose that laid the golden egg.;)
bruce88123 02-18-2007 10:10 PM
ORIGINAL: johntammi
Sorry but no. Not meant to be used like an ESV.
flyinrog 02-18-2007 11:06 PM
ORIGINAL: piper_chuck
ORIGINAL: flyinrog
I have a Voltwatch on each of my larger planes..but I keep one in the flight box for my 1/2A stuff ..but I know some of them are only good for a few flights, I have batteries down to 110 Mah for the small racers..most of them are 270Mah but they only fly for 3-5 minutes per tank..Rog
Rodney 02-19-2007 08:06 AM
IMHO the Voltwatch is far superior to an ESV (expanded scale voltmeter) because it gives you a lot more information than an ESV does. Of course it has to be mounted where you can see it when you start or finish a flight. If you see the little lights jumping back and forth when you move the sticks, it is telling you that the voltage is varying at the point you have the Voltwatch plugged into which means that 1: the wiring between the Voltwatch and battery is to small or 2: the switch contacts have high impedance or 3:one of the servos is drawing excessive current when in transient conditions. If you monitor the reading at the end of a flight before turning off the switch, it gives you a very reliable "State of Charge" that exists under the actual load you are using. If you use a Voltwatch, it gives the most reliable information when plugged directly into one of the reciever unused channels, a Y off one of the other channels can have the information slightly distorted by the IR drop in the wire between the receiver and Voltwatch. If plugged directly into the battery connector (before the on board switch) the information you get is severly compromised as it eliminates any info you get about the voltage drops in the switch and associated wiring; the same lack of information you get when you plug a ESV into the charging plug. This is not a condemnation of an ESV, just that the Voltwatch is a much better option.
