PT40 wing washout
Can you build the PT40 without the wing washout and how will it fly.
Build a LT40, LT25, 4*40, and ARF Fun FLY p51 by Thundertiger None have washout in the wing and have no problem flying them. Been flying the LT25 with skis off the snow without any problem. No problem with loops or barrel rows. |
PT40 wing washout
yes, inverted will be better, washout is to prolong the wing stalling,without washout you will stall a little faster,recovery will not be as good or fast,depends on your skill level if you like it or not with out washout.
| All times are GMT -8. The time now is 01:28 AM. |
