Glue
Hi, I am just wondering what the best temp is for glueing? I have my shop in the garage and it is here about - 10Celcius. The garage is about 0Celcius. Is this to cold to glue?
Thanks Ralf |
RE: Glue
0 degrees celcius (32 degrees F) isn't the warmest temperature to be working in for glue. I would want it to be at least 12 degrees celcius. I would find a nice table in the basement.
"Titebond recommends above 50 degrees F. Do not use when temperature, glue or materials are below 50°F. Freezing may not affect the function of the product but may cause it to thicken." "In general, Epoxy should be applied at room temperature. In colder temperatures, the epoxy-curing rate tends to slow down. It may require heat to help generate the cure. Always keep the Epoxy at room temperature in order to assure the best cure rate." |
RE: Glue
32 degree shop??? Get a heater! Lots of things don't like it that cold, including glues, finishes, electronic equipment, and even wood.
Dr.1 |
RE: Glue
You forgot feet, ears, noses, finger tips, etc.
The only thing I can think of that likes the cold is the beer. KW_Counter |
RE: Glue
I`ll drink to that. lol
ORIGINAL: KW_Counter You forgot feet, ears, noses, finger tips, etc. The only thing I can think of that likes the cold is the beer. KW_Counter |
RE: Glue
I hear that, normally we have mild winters and my garage shop is just fine.. go figure the year I get a kit @ christmas the snow's flying and temperature plumets.. gota play catch up as sprint flying is just around the corner
| All times are GMT -8. The time now is 02:18 AM. |
