RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Add or Remove (https://www.rcuniverse.com/forum/beginners-85/5571832-add-remove.html)
Bluefuzzyone 03-16-2007 06:24 PM
Add or Remove
1 Attachment(s)
I am a Newbie at RC Fixed Wing. I have just built a Spad Trainer an a friend has given me an OS 46 AX Engine for it. I would like to balance the propeller for it on a balancer I use to balance Helicopter blades. I have searched the site on information about balancing props but I need more information.
Question ---- How do you make the blades balance? ...... Add weight to the lighter side or remove material from the heavier side.
agexpert 03-16-2007 06:31 PM
RE: Add or Remove
ADD
oh, and I use medium CA on plastic, wood and CF props to add weight to the light side.
Bluefuzzyone 03-16-2007 06:39 PM
RE: Add or Remove
Thanks for the info. I have not flown a plane yet so I am trying to solve any problems that may arise before my first CRASH. LOL
a65l 03-16-2007 06:43 PM
RE: Add or Remove
Wood props I usually spray the light blade with clearcoat. Nylon/plastic props I usually sand the backside of the blade. OR paint the tip (s).
A
P-40 DRIVER 03-16-2007 06:49 PM
RE: Add or Remove
I have found that APC props are usually so close, you don't need to balance them. I usually sand the finish to balance wood props
Bluefuzzyone 03-16-2007 06:49 PM
RE: Add or Remove
I will be using plastic I think to save replacement cost. Sanding seems like a good Idea as you can balance in two dimentions.
bigtim 03-16-2007 11:09 PM
RE: Add or Remove
if your new you will have nicked the prop on the ground after the first flight and all the balancing that you did will be waisted.
generally I check the balance to make sure the prop is not totally out of wack, wood props tend to be close, plastic can be all over the place.
I have APC props that are perfect,and also so out that I wouldn't run it at all, it depends on each prop individually.
for the 46 sizes 10/6 to 12/4 on a trainer,for a plastic prop sand the heavy blade on the back side.
for wood a combo, sand a little, and clear coat the sanded area as well as the light side when dry, recheck-repeat.
when you get to larger props balance becomes extremely critical not only for the engine but the airframe the wear and tear from a out of balance prop can be fatal.
Dr1Driver 03-17-2007 08:50 AM
RE: Add or Remove
DO NOT sand or carve to balance a prop. Composite props shouldn't be sanded at all. Use clear poly-u to spray on the light side of the prop until it balances. If a prop really smacks down to the heavy side, return it and get one that's more in balance.
Dr.1
aerowoof 03-17-2007 01:38 PM
RE: Add or Remove
when sanding wood props to balance them you do not sand the back as that is what sets the pitch
