Fuel tank question
I'm putting my pulse xt arf together. The fuel tank seems like its higher than carb. Is this going to be a problem? Any tips advice please.
RE: Fuel tank question
I put the tank into the normal location in the plane and with an OS 46 AX mounted up front it's no problem at all. I didn't look to see where they were in relation to each other but it works fine.
Did you how did you route the fuel line? |
G'day Mate,
I maidened a Pulse XT for a member of our club a couple of weeks ago, he used an OS FL70 in it, & mounted it upright, the needle valve was very high compared to the tank. So I would mount the engine, sideways, & that will lower the needle valve & save problems with tuning. |
| All times are GMT -8. The time now is 02:52 AM. |
