RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Alittle update (https://www.rcuniverse.com/forum/beginners-85/5664844-alittle-update.html)
blkz2801 04-04-2007 02:13 PM
Alittle update
Ok fellas, i got the wind together and when i was made the 90 degree bend in the wire to attach the servo arm to it, the wire snaped off :(. So I contiued to build. Then next part was to install the gas tank. The instructions call for slicone around the fuel tank. Do I really need this? Thanks for all your help
MinnFlyer 04-04-2007 03:04 PM
RE: Alittle update
If you don't have silicon, you could just stuff some foam in there
Insanemoondoggie 04-04-2007 04:33 PM
RE: Alittle update
If this is a Tower trainer, they drill a big hole in the firewall for the fuel cap to stick thru, and you need to RTV around it to seal it from leaking fuel to the inside. If insulating the tank, like MinnFlyer said, shove some foam around it.
blkz2801 04-05-2007 12:35 PM
RE: Alittle update
were can i get rtv around were i live? I dont have a LHS
bigugly 04-05-2007 01:01 PM
RE: Alittle update
any auto parts store will have it
MikeL 04-05-2007 01:02 PM
RE: Alittle update
Any hardware store or automotive supply store will have it.
