Beginner Equipment? Spadet?
I want to get started in this hobby and always have, but I am one a very limited budget until I can get out of college. I have gotten the plans for the spadet and am wanting to start building. Now time for some questions.
Do I need to flash or can I use the scotch brite, mineral spirits method? Do these methods need only done where the glue will go? I am set on getting a 4 channel radio, but is it OK to buy a used one on ebay or something?, I would like to be able to switch it into an electric flyer someday, if the desire hits me. What about a used engine? Any brands or models on the radio and engine? I am an engineering student so the building of the spadet looks fun to me. The airplane I am pretty set on, but everything else is in the air. Thanks for the help |
You didn't ask, but I'll jump in here anyway...
Before you start buying and building, I highly recommend you think about how and where you are going to learn to fly. The traditional method (find an instructor at the local club) is not cheap. Most clubs charge dues around $50 and AMA dues (also around $50 a year) are almost always required as well. Even with a Spadet, the chances of learning on your own are slight, and you'd need a place to fly. There are serious safety issues involved with flying glow-powered R/C planes, and you need to understand them. Take the time first to figure out this issue. I suggest visiting a local flying field. Once this is settled, you're ready for the fun. |
Hey Iceman,
Pinball is right, but you also can get an answer to your questions. As for the SPADs, you might want to ask on the SPAD section of RCU, you'd probably get more help re. actual SPAD building. I built one (tried several times on the wing to get it right...), and found that sanding the coro surface, then wiping with alcohol is the way to go to prep the surface. Then glue with medium or thick CA. You only need to do it where there are glue joints. As for radios/engines, I would be more careful on Ebay than on RCU. PArticularly with radios, you need to make sure it is still a legal radio, and some people on EBAY might not know the difference. I personally think you can get used/nearly new stuff from guys on RCU's classifieds, and save a few $. As for brands, everyone has a favorite, I use Futaba radios and OS engines, but that doesn't make them any better than other good brands. The thing to do is narrow the question down, and maybe ask it in terms of what might be bad about a certain engine or radio. If you ask what is the best, you'll just start a debate and never get a definite answer. good luck! |
Thanks for the replies,
There is an RC field and club here where I live and I have been out to the field, but am not a member yet. However, I would join before trying to fly and have a member help me get started. I just figured that would probably come after I had build a plane and had equipment. On the equipment matter I guess what I am mainly asking is if an older radio (like for instance a conquest 4 by futaba) would be the way to go or is it better to buy new? What about AM or FM radios? thanks |
Re: Beginner Equipment? Spadet?
Do I need to flash or can I use the scotch brite, mineral spirits method? Personally, I use a primer made for coro and CA. No muss, no fuss. Do these methods need only done where the glue will go? I am set on getting a 4 channel radio, but is it OK to buy a used one on ebay or something?, Pay attention to the seller's rating and comments from other buyers! I would like to be able to switch it into an electric flyer someday, if the desire hits me. What about a used engine? I am an engineering student so the building of the spadet looks fun to me. The airplane I am pretty set on, but everything else is in the air. |
Originally posted by Iceman1 I want to get started in this hobby and always have, but I am one a very limited budget until I can get out of college. I have gotten the plans for the spadet and am wanting to start building. Now time for some questions. Iceman1, Check your budget first the SPAD planes themselves are much less expensive to build, but the rest of the gear costs the same. Figure about 50-100 (cost of balsa ARF Trainner)savings when taking the SPAD route. Now most guys here feel 300-600 is about what it takes to get into this hobby. Subtract the 50 to 100 and thats what you will need. I would hate for you to run out of funds midway through your project... |
Re: Re: Beginner Equipment? Spadet?
my suggestion... go to the field... maybe someone their has a setup they are willing to sell cheap. esp someone that has learned to solo and has moved on in planes. you might be able to get a good trainer without any building... then you can start with spads after you get a few flights under your belt.
also you would be talking to the person selling which is a big plus (know what your getting) and you might make a few freinds. |
Re: Re: Re: Beginner Equipment? Spadet?
Originally posted by Iceman1 Can you tell me the name? Maybe where you bought it? |
| All times are GMT -8. The time now is 02:57 AM. |
