RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Nexstar Steering (https://www.rcuniverse.com/forum/beginners-85/5720542-nexstar-steering.html)
swimman 04-15-2007 05:04 PM
Nexstar Steering
Just repaired my Nexstar from a landing that removed the gear. I noticed when installing the front wheel that the wheels turns further to the left than the right due to the coil (spring) making contact with the firewall when turned to the right. Not sure if this is how it's supposed to be or if my not-so-pleasant landing bent things. Thanks for the help.
rwright142 04-15-2007 05:11 PM
RE: Nexstar Steering
Thee coil may be push too far up, towards the top of the plane. The wheel should turn in both direction equally. Can you send a picture?
bruce88123 04-15-2007 06:38 PM
I just looked at the Nexstar manual and it clearly shows that the bottom of the coils is even with the bottom of the fuselage.
Remember that the nose wheel only needs to turn a few degrees. This isn't supposed to be a slalom racer. At the most you want to be able to turn around using the FULL width of your runway. Too sensitive of a nose wheel just makes it more difficult to handle on takeoff.
horace315 04-15-2007 08:36 PM
they should turn equal if you have a computer radir set the throws for that,otherwise it isnt going to hurt turnning more in one direction as long as it steers straight.like bruce said you only have to turn a few degrees in either direction.
