?? chicken stick ??
can anyone tell me what a chicken stick is, i know it's for starting
an aircraft engine but what dose it do & how do you use it? :confused: |
?? chicken stick ??
It's anything (other than your finger) that is used to flip start your engine. most people just use a piece of wooden dowel rod.
?? chicken stick ??
I new too, but I would guess it is called that because you are chicken not to use your finger, so chicken stick???
?? chicken stick ??
does that do any damage to prop?
?? chicken stick ??
If it is padded with plastic or rubber then you will be fine. I made a large chicken stick out of some PVC, covered with PVC insulation. I found that my large plastic props were cutting the insulation, so I wrapped with with Duct Tape and it has worked great ever since.
?? chicken stick ??
Master Airscrews make good chicken sticks.
?? chicken stick ??
If you don't want to ue a chicken stick, use an welding glove. You need to protect your fingers and hand.
?? chicken stick ??
Duct Tape Application # 9,678,452,324 "Chicken Stick" has been logged, right behind "Bio hazard window defence treatment".
?? chicken stick ??
1 Attachment(s)
Hi mobil_racer
You should check out the RC Humor room Here a sample of a chicken stick lolllll Take care the old guy |
Chicken Stick??
I prefer the term "Smart Stick"
'cause your a moron if you use your bare fingers to start any internal combustion engine. IMHO |
?? chicken stick ??
Piece of wooden dowel wrapped with electrical tape. When the tape starts falling off because it's getting cut to shreds...... re-wrap with new tape and keep on flippin!!!!!
Why buy when you can build with scrap from your shop??? |
?? chicken stick ??
Yes, the term "Chicken Stick" DOES derive from the days when men were men and fingers were missing. Only a "Sissy" wouldn't use his fingers to start a prop.
Fortunately, common sense finally prevailed. Rcpilet is correct... "SMART stick" is what it SHOULD be called. |
?? chicken stick ??
So did the guy with the shoe get the engine started?
Originally posted by old guy Hi mobil_racer You should check out the RC Humor room Here a sample of a chicken stick lolllll Take care the old guy |
?? chicken stick ??
Is that what you call a "running start"?
?? chicken stick ??
I just havnt figured out why he took the shoe OFF!?
?? chicken stick ??
Car heater hose on dowel. You still get buzz with welder gloves . Take foot from shoe.
?? chicken stick ??
Originally posted by MinnFlyer Yes, the term "Chicken Stick" DOES derive from the days when men were men and fingers were missing. Only a "Sissy" wouldn't use his fingers to start a prop. Fortunately, common sense finally prevailed. But strangely, this attitude is limited to RC fliers who have engines that at idle put out about as much HP as a .049! Seriously! On the other hand (and with all fingers intact :) ) CL fliers will happily hand start piped .60's which naturally only run at full throttle. I'm not saying there's anything wrong with either electric starters or chicken sticks but if you've got half a clue how to start an engine then even by hand it's quite safe. The REAL danger is putting your hand through the prop once the engine is running. |
?? chicken stick ??
This not a joke . If a motor back fires and you have a finger in the prop you are possibly going to get stiches. We like to joke some times but most jokes are a truth time tested and proven . Hope you do nodt learn the hard way .Been doing this fo 55 years and still not to old to learn. Good Luck.
?? chicken stick ??
I've found that the cheap $3 hobbico chicken stick works great.
http://www2.gpmd.com/image/h/hcap3335.jpg It's end is made of hard rubber that will not tear up a prop, yet at the same time has enough stiffness to turn over an engine. |
?? chicken stick ??
Originally posted by downunder if you've got half a clue how to start an engine then even by hand it's quite safe. Last week, I was tightening a prop on a Saito 150 in my basement. After it was tight, i spun it through it's compression stroke. No fuel, no glow, I simply turned it over. Once it got past TDC, the prop flipped over and whacked the back of my finger so hard I thought it broke it. All I could think of was "I'm glad that didn't happen outside in the cold". I have been starting engines for over 40 years, I was hit by a prop once as a teenager (and you're right, it WASN'T while starting). You'd think I would know better, but it boils down to this: ACCIDENTS HAPPEN! |
?? chicken stick ??
I just havnt figured out why he took the shoe OFF!? |
Joe Ortiz
It was bad plane
not listen to master and bit back lollllllllll |
?? chicken stick ??
forty years ago when garden hoses were made of rubber, the 12
inch sections of what was left after driving over the conectors made great chicken sticks. The rubber was stiffer than current vinyl and had much thicker walls. with a search you can probably find some and have a lifetime supply for free. |
?? chicken stick ??
our own Marc (RCAdmin) was flipping his new 4-stroke for his ultimate (see review) with a chicken stick... well he flipped and it kicked back hard enough to snap the chicken stick in half and fling the padding 20 feet.
imagine. if that were his fingers he would have a hard time keeping this site up and running. chicken sticks are a Good Thing(tm) oh.. if I flip start I find broken wood props work pretty good. |
?? chicken stick ??
If you don't know what "chicken stick" is by now you'll finger it out later.
| All times are GMT -8. The time now is 12:43 PM. |
