Landing gear
Does anyone know of a website with a good selection of landing gear. I am looking to replace the gear on my .40 size electric trainer however am having trouble finding anything that fits the current specs.
RE: Landing gear
what are the specs for it? the specs u wanna know are the (1.) base plate height,length, width (2.) Distance from top to bottom (so from base plate top...to base of landing gear legs (3.) Distance between the landing gear legs and/or distance between the landing gear wheels.
-David |
RE: Landing gear
Does it keep the prop off the ground. That's all you need. :D You can always make it fit the fuselage.
Dr.1 |
RE: Landing gear
ORIGINAL: e-flight22 what are the specs for it? the specs u wanna know are the (1.) base plate height,length, width (2.) Distance from top to bottom (so from base plate top...to base of landing gear legs (3.) Distance between the landing gear legs and/or distance between the landing gear wheels. -David 4" 15" |
RE: Landing gear
I use hobbytown for my parts. The staff are pretty knowledgable here in Lou. KY. They also have a decent websight. You could also google your plane and look for a sight that sells parts for it. But hobbytown is my choice.
RE: Landing gear
RE: Landing gear
RE: Landing gear
RE: Landing gear
Racer....thanks for the link...that one gets a bookmark!
| All times are GMT -8. The time now is 01:21 PM. |
