RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   What should I be looking for? (https://www.rcuniverse.com/forum/beginners-85/5821791-what-should-i-looking.html)
cjposada 05-07-2007 07:49 AM
After rolling out my superstar sellect trainer, when it is reaching flying speed, the left wing diggs into the ground so right aileron is a must in every take off. What should I be looking for to correct this tendency? It flyes level hand free after take off.
RCKen 05-07-2007 07:53 AM
RE: What should I be looking for?
cjposada,
Was this just one day at the field? Or has this happened more than one day? Was there a crosswind when you were flying it??
Ken
Insanemoondoggie 05-07-2007 08:29 AM
Might be your engines thrust angle , if you have hands off flight.
MinnFlyer 05-07-2007 09:30 AM
Might be you're leaving the ground before you have sufficent airspeed. Try holding it on the ground a little longer.
cjposada 05-07-2007 11:24 AM
We had the wind comming down the runway all weekend long so I don't think this is an issue. I had to take the engine out to threadlock the motor mount. Since this is a clamp on mount I am going to doublecheck the engine's alignement.
Thanks for the input.
