airplane out of range
hello:
what happen if my plane get out of range? how i will know my plane range thank u |
RE: airplane out of range
Seedo, I'm not trying to make a joke out of this because it's really pretty serious subject. But if your plane flies out of range it's going to crash. It's just that simple. How far it continues to fly before that crash depends on a lot of factors. It's possible that the plane could travel many miles before it crashes, or at other times it will just spiral in quickly and crash. The easiest way to tell that you plane is out of range is that it will not longer respond to the control inputs you give it.
Ken |
always do a range check.
I think it's safe to say that you will lose sight of the plane before you lose any radio reception
If you want to know the range of your radio...Well...the answer has nothing to do with radio range. You can't control your aircraft if you can't see it. By see it I mean its attitude, direction etc.
Good Luck |
thank u guys
If you want to find out just what your plane will do with a loss of radio signal, turn on your transmitter, then the receiver, activate the motor and put it on full speed, start moving your control surfaces around and turn off the transmitter.
On mine, the motor stops and the control surfaces neutralize. This will put the plane in a glide for a straight-in landing (if nothing gets in its way). |
ORIGINAL: Sir Raleigh If you want to find out just what your plane will do with a loss of radio signal, turn on your transmitter, then the receiver, activate the motor and put it on full speed, start moving your control surfaces around and turn off the transmitter. On mine, the motor stops and the control surfaces neutralize. This will put the plane in a glide for a straight-in landing (if nothing gets in its way). If you think to the contrary, please tell me what miracle device you have installed. Even the so-called autopilots out there won't do what you have concieved. |
ORIGINAL: bruce88123 ORIGINAL: Sir Raleigh If you want to find out just what your plane will do with a loss of radio signal, turn on your transmitter, then the receiver, activate the motor and put it on full speed, start moving your control surfaces around and turn off the transmitter. On mine, the motor stops and the control surfaces neutralize. This will put the plane in a glide for a straight-in landing (if nothing gets in its way). If you think to the contrary, please tell me what miracle device you have installed. Even the so-called autopilots out there won't do what you have concieved. I'm sorry if I offended your sensitives about what some other plane will do. Please pardon my ignorance for posting something I've actually seen happen. |
Sorry, I was talking about REAL planes and not those little junk toys.
if your plane is out of sight its probably not out of radio range,if you have a general idea of the direction then try to head it back your way.
if you have lost it then you should have your name address and ph.#as well as your AMA# inside your fusalage in case someone finds the plane/wreckage. a perfect example; our field is on a plateu above the Pacific Ocean, a member crashed in the drink, the cliff is 150 ft high so its gone for sure theres no way to get down there without a boat. couple of days later he gets a call from a local guy about a missing plane he found a mile off shore while fishing not too much left to salvage but he did clean out the engine and it ran fine even after the salt water bath. point is keep your plane within your sight and put your info in the plane for identification. |
Also bear in mind that there are different types of receivers used that affect range as well.
Typically the smaller RX's that are available ( with exceptions ) are used in park flyers, which spend most of their time close in. These have fairly limited ranges, often down to 500 ft. You don't want to make the mistake of putting one of these RX's in a large plane, although some of the better Park Flyer RX's rival their bigger brethren. |
It's possible that the plane could travel many miles before it crashes, or at other times it will just spiral in quickly and crash. |
| All times are GMT -8. The time now is 12:01 PM. |
