RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Prop size + engine.. (https://www.rcuniverse.com/forum/beginners-85/5933561-prop-size-engine.html)
skaap2k 06-02-2007 05:17 AM
Hi,
I was recommended to use a 13x6 prop with my OS 55AX engine, however, the hole in the prop is larger than what's on the engine, what do you do in this case?
Thanks in advantage! :)
RN
alan0899 06-02-2007 06:34 AM
RE: Prop size + engine..
G'day Mate,
I would turn up a bush, on my lathe & insert it in the prop, to reduce the hole size, or you could just buy another prop.
MinnFlyer 06-02-2007 08:05 AM
I would just wrap a layer of tape around the drive shaft
I can hear the nasty comments already, but I've done it many times with no problemo
Trollmaster 06-02-2007 08:51 AM
I've done that. Why a 13/6? Thats kind of on the higher side here. What ya flying?
Deadeye 06-02-2007 10:33 AM
ORIGINAL: MinnFlyer
Minn's got it right.
Big feet 06-02-2007 12:05 PM
ORIGINAL: Trollmaster
I agreed with this at first, but then I thought, a 60 normally runs an 11x7, I surpose its not too far out for a 55, you could step the diameter down to 12 if the engine wont peek out.
Tape is a good idea, I have never had this problem. It's nice to get a solution before the problem for once.
scratchonly 06-02-2007 12:13 PM
You can likely find a size of brass tupe which will make a good shim.
skaap2k 06-02-2007 12:48 PM
I put the question here simply because I thought it was a fairly simple question, and I had never come across this problem before with my other models.
Making some sort of collar is out the question mostly - finding someone who has a lathe capable of making small bits like that is near to impossible in this country!!
I'm building (assembling) a TF Cessna 310 and looking around here and talking to others, a 12x7 or 13x6 2 blade props are ideal for this engine+model... feel free to correct me, but either of those 2 made sense!
Thanks again..
RN
Big feet 06-02-2007 01:26 PM
Yes, they sound OK, you are not looking for outright performance I expect with that model, more like a quiet engine. If that is the case try the 12x7 first, it is like using a slightly higher gear.
JPGale 06-03-2007 12:28 AM
APC recommend using fuel tubing as a bushing.
scratchonly 06-05-2007 10:47 AM
Where did you get this information? I checked their web site and found nothing.
carrellh 06-05-2007 11:31 AM
You could possibly take your engine to a hardware store and buy a length of brass, copper, or aluminum tubing that is a good fit on the shaft. Then ream the prop to fit the outer diameter of the tubing.
The following 13x6 props have a 1/4" (or smaller) hole, which can be reamed match the shaft:
APC 13x6 Sport Prop
Master Airscrew 13x6 S-2 G/F Nylon Gray Propeller
Master Airscrew 13x6 K Series G/F Nylon Propeller
A lot of the wood props are described as having a hole diameter of approximately 1/4" so there's a chance they are oversize.
I know there are lots of prop brands available. The ones I listed are what I have actually used. My engines all have 5/16" shafts So I have to ream all of my 12 and 13 inch props.
