Epoxy ?
I am getting ready to buid my first arf. It's a sig 4 star 40. I have this epoxy laying around and it new and wanted to know if i could use it? I dont see why i cant. Thanks for the help
http://www.lowes.com/lowes/lkn?actio...007&lpage=none |
RE: Epoxy ?
Personaly I wouldn't use it. I don't like the double plunger thing for me it's actualy been less accurate than using a mixig cup. Unequal amounts of epoxy, mixed can be a real hassle Also 5 min epoxy set's real fast, it doesn't give you much working time, 15- 30 min epoxy would be better and stronger. Additionaly I've found the hobby brands to be of a better quality IMO
Can you use it, Yes. Would I use it NO. Darren |
RE: Epoxy ?
The manual said to you 5 min for what im doing now. I do have 30 min hobby epoxy. I use that instead.
Thanks Darren |
RE: Epoxy ?
You can always use a slower epoxy. You can get in trouble using faster epoxy as it can easily "set up" before you are ready.[8D]
RE: Epoxy ?
Thanks for the info. I asked someone at the field and they said the same thing.
| All times are GMT -8. The time now is 05:45 AM. |
