Kadet Senior Engine Mount Position
HI,
I know the Kadet is technically a trainer, but the firewall is slow slowped down. I want to put somekind of shim so the engine will mount level. I don't have a belt sander to make a nice shim. How else can I level out the engine mount? Thanks! |
RE: Kadet Senior Engine Mount Position
The Kadet requires a LOT of engine downthrust. This is normal, and is used so that at higher throttle settings it doesn't balloon.
Flying with down trust raises the angle of attack on the wing, which will make it climb.
You got it backwards dude...
Look, just trust the manufacturer on this one. There is just a very slim chance that they MIGHT know better than you on this one. If you don't like the way it flies, you can always screw it up later.:D They've been marketing this plane for a real long time. If it was broke they would have corrected it by now. SIG is just about the best company in the business.
1 Attachment(s)
Here is a pic of the sig senior with no cowl or cheeks, It may be hard to see but that engine is tilted rather far down. But the plane flys
like a dream and and even after my friend and I finished training on it and have moved to other planes, We haven't touched the setup, and the plane flys every few weeks. I agree with bruce leave it as it was designed. If you still don't like it after flying for a while add small spacers to the bottom engine mount bolts and try it like that. |
I know the Kadet is technically a trainer, but the firewall is slow slowped down. I want to put somekind of shim so the engine will mount level. I don't have a belt sander to make a nice shim. How else can I level out the engine mount? As explained by others above, that is a bad choice. The Kadet needs down-thrust. ORIGINAL: garywi Flying with down trust raises the angle of attack on the wing, which will make it climb. ? With a straight engine thrust line, you will have to trim the elevator to maintain straight flight at any gven airspeed. Pull off power, and the machine will dive. Add power and the machine will climb as it seeks to maintain the airspeed that you trimmed for. Induce downthrust and now when you trim for level flight all is well-- and when you pull the power back, the trim offsets the thrust that was pulling the nose down, thus the machine will tend to maintain the flight line established prior to reducing power. By the same token adding power will create more nose-down against the previously set trim, thus reducing the tendency to climb. Any flat bottom high-wing will do this. Down-thrust is the answer. The original SIG Kadet was the main trainer of the '70s. SIG did not show downthrust. We had to install it for the newbies. Now that SIG is run by real modelers, I think they understand the basics. I suggest you go with the aerodynamics rather than the cosmetics. A pilot only needs to know the lift formula that HE can control, which is reduced to Lift = AOA x 1/2 V squared. (Lift = coefficient of lift [AOA] times 1/2 of the air mass density, times velocity- squared, times the wing area.) Use the downthrust. |
| All times are GMT -8. The time now is 10:13 AM. |
