RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Assembling Dowl Based Push rods (https://www.rcuniverse.com/forum/beginners-85/6009149-assembling-dowl-based-push-rods.html)
garywi 06-19-2007 07:00 PM
Hi,
So, I have everything put together for rudder and elevator pushrods on this Kadet Senior. I have the shrink tubing on the ends.
I was wondering if you add an extra bit of protection, and place a small zip tie on each end, to make sure that wire never comes out of dowel? I did epoxy as well.
G
piper_chuck 06-19-2007 07:02 PM
RE: Assembling Dowl Based Push rods
Rather than using shrink tubing, I usually wrap string or thin uninsulated wire around it and then epoxy it in place.
Cyclic_ Hardover 06-19-2007 09:44 PM
Shrink tubing that comes with it is not a good idea.I go along the same lines as Piper here. I wrap it in with very thin fibeglass cloth with epoxy soaked in it. Very stable this way
DavidAgar 06-19-2007 09:45 PM
I wrap my ends in thread and use thin CA to seal the thread. I am thinking a tie wrap might have the chance to get hung up on something. Good Luck, Dave
horace315 06-19-2007 09:53 PM
i dont use the dowls in the kits rather use nyrod and metal rod combined with the nylon tubes.they are about the same weight mabey a little less and not as many worrys about them failing.
B.L.E. 06-19-2007 09:54 PM
Ditto with wrapping with thread and saturating with CA glue (or epoxy if you prefer). In fact, that's what the instructions used to tell you to do when I built a Kadet Senorita.
Look at the line guides on a fishing rod and you get the idea of what to do.
