RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Nose drops when throttle is cut. (https://www.rcuniverse.com/forum/beginners-85/6017618-nose-drops-when-throttle-cut.html)
xray328 06-21-2007 06:23 PM
I was flying my electric MM Magpie today. All went well, but when I cut the throttle, the nose drops to about 25 degrees down. I set the CG per the instructions on a Great Planes CG machine. What would cause this? The battery is being used to adjust balance, and even moving the battery back two inches didn't help.
Thanks in advance!
iron eagel 06-21-2007 07:31 PM
RE: Nose drops when throttle is cut.
For a high wing that is common although that much of a change 25 degrees is a bit much. I would add a bit of down thrust, that should help tame the beast a bit.
CGRetired 06-22-2007 06:08 AM
Would moving the CG back slightly, meaning a very small amount, like a quarter of an inch.. help?
Rodney 06-22-2007 09:04 AM
As iron eagle says, add some downthrust; most will require about 5 degrees and also usually need about 3 degrees right thrust.
LuftwaffeOberst 06-22-2007 09:35 AM
Double Post.
LuftwaffeOberst 06-22-2007 09:41 AM
ORIGINAL: CGRetired
I'm with you on this one... I'd re-check your CG. When I hit my flaps on my Mustang my planes nose pitches up slightly because of lift, reduction of speed... and being slightly tail heavy. ( And I mean very slightly tail heavy) I wanted it that way so it would behave more like the real P-51. ;)
Luftwaffe Oberst
Radio Aero Modelers Club
AMA District II
Pulaski, NY
broke_n_bummin 06-22-2007 11:19 AM
... But adding downthrust is only going to help when the propeller is turning. He said that when he cuts the throttle, it pitches down. Sounds like a stall ... like you're going too slow. The extreme dihedral wing will keep the plane straight, but it sounds like the plane is falling out of the sky. After it dives a bit, does it straighten out for a minute then dive again (porpoising) ?
VFR_RC 06-22-2007 11:49 AM
On full size airplanes (like cessnas) it's very normal. It's called downwash and it's when the spinning draft coming from the prop hits the stabilizer on the top and keeps it leveled. When you cut the throttle, this force is removed and the nose pitches down. T-tail airplanes don't have this issue.
Kaos Rulz 06-22-2007 11:52 AM
ORIGINAL: broke_n_bummin
If there is too much up-thrust, he's having to dial in down elevator for straight flight under power. Reduce the power and the down trim causes the plane to nose downward. To correct this, you shim some down-thrust in the engine to hopefully take out the down trimmed elevator. Once the correct engine thrust is dialed in, the plane should initially continue flying straight when the power is cut. After air speed is reduced, then the plane will lose altitude.
Big feet 06-23-2007 04:24 PM
ORIGINAL: ED STEFAN
I agree, the pattern planes use this method to trim the model for different power settings to stay in level flight.
Shim the thrust angle down a little more and try the throttle test again.
xray328 06-23-2007 07:59 PM
The motors angle is preset from the manufacturer. It flys fine under power, but as soon as the powers off, its just wants to nose dive. Its not porpoising though, its just nose down, and it would just nose in like that if I let it. CG is dead on.
dcook07 06-23-2007 08:14 PM
Sounds like there is an alignment problem and you were able to trim it out under power! I'd set it up on your bench and " bench trim it!!
DDCook
N1EDM 06-23-2007 10:04 PM
I'm with DCook and Lufftwaffeon Oberst this one. I'd check the alignment and and CG. Did you do anything like change to a larger (i.e., heavier) engine, or something else that could have changed trim?
I'd recheck the basics first... Let us know what you find.
Bob
xray328 06-23-2007 11:14 PM
It looks like the motors angle did change after all. The mount is in foam and after awhile the foam gave a bit. It was only a few degrees but it made a difference. Thanks guys!
N1EDM 06-24-2007 07:07 AM
Keep us posted on your fix...
Bob
iron eagel 06-24-2007 08:13 PM
A change of a few degrees will make a big change in how the airplane will fly. If your cg is right it comes down to things like AOI and thrust angle. Typically the thrust angles in models are a max of about 5 degrees, change this by a only a few and there will be a major change in how it flies.
