Does peel and stick Mono-Kote Shrink?
Hi,
Do those peel and stick monoKote strips shrink with a heat gun? I want to use some for patching. Thanks |
RE: Does peel and stick Mono-Kote Shrink?
They will, but they are not designed to, and you won't like the result. If you want to patch, use the same color Monokote and cut a bit bigger than area to be patched. Use an iron to attach around the patch area then shink down to tighten. OR..... use clear packing tape if you don't care about apearance.
| All times are GMT -8. The time now is 01:49 AM. |
