Flaperons????
Was thinking of trying the flaperon option on my SIG Four Star 60.
Anyone have any advice about using the function? |
RE: Flaperons????
It doesn't take much to slow this already slow landing airplane. You will need to mix or manually feed in down elevator, as the plane will tend to pitch up when flaperons are deployed. This plane really doesn't need it, but it is still fun to play around with.
RE: Flaperons????
Thanks for the help
The down elevator was what I was wondering about most. It will be fun to give it a go. |
RE: Flaperons????
ORIGINAL: Deadeye It doesn't take much to slow this already slow landing airplane. You will need to mix or manually feed in down elevator, as the plane will tend to pitch up when flaperons are deployed. This plane really doesn't need it, but it is still fun to play around with. |
RE: Flaperons????
Interesting... I have a Futaba 6EX-2.4 GHz radio. I like having the ability to dial in a real short landing, just going to have to be mighty careful as I feel this stuff out :D
RE: Flaperons????
flaperons down will make this airplane balloon up requiring down elevator. The 4 Star 60 was my second airplane. Built from a kit I made a noob mistake and had the ailerons adjusted wrong. had them adjusted so that the top of the aileron followed the top of the wing, perhaps a droop of 4 or 5 degrees? airplane handled horribly, that was my instructors words
be careful |
RE: Flaperons????
ORIGINAL: broke_n_bummin ORIGINAL: Deadeye It doesn't take much to slow this already slow landing airplane. You will need to mix or manually feed in down elevator, as the plane will tend to pitch up when flaperons are deployed. This plane really doesn't need it, but it is still fun to play around with. |
RE: Flaperons????
ORIGINAL: Missileman ORIGINAL: broke_n_bummin ORIGINAL: Deadeye It doesn't take much to slow this already slow landing airplane. You will need to mix or manually feed in down elevator, as the plane will tend to pitch up when flaperons are deployed. This plane really doesn't need it, but it is still fun to play around with. |
RE: Flaperons????
I put flaperons on my 4*60 just for fun. You really don't need to do it for landing, the plane goes really, really slow anyways. I do want to try to hoover it horizontaly one of these days in a stiff breeze just to see if I can. For takeoff, now that is neat!
I have a OS .70 Surpass on mine. Normal take off roll is about 10-15 feet with 1/2 throttle. When I put the flaps down the plane takes off in about 4-5 feet. |
RE: Flaperons????
I have an Evolution 61 on my 4* 60 . It is very reliable but not extremely powerful. Good for me at this point in my learning curve
| All times are GMT -8. The time now is 11:12 AM. |
