Hangar 9 ALPHA 40
In search of replacement trainer. My SIG suffered fatal injuries so it needs replacing. Found a Hangar 9 ALPHA 40 that is a few years old and I'm wondering if they came out with a .40 size evolution engine or a .46 ? The reason I'm asking is because my SIG had a .40 OS and my brother has a .46 evo in his trainer and the Alpha engine looks exactly the same as the .46 of my brothers. Especially the intake hole.
RE: Hangar 9 ALPHA 40
think mine has a .40 on it. i will go check for ya later. great trainer though. the engine is dead reliable. almost never have to mess with the needles unless there is a huge swing in the temp outside. plane flies and takes of/lands beautifully. it is also pretty capable if you set the throws to max. you might surprise yourself what you can do with that plane. wing is held on with rubberbands for quick setup and easy transportation. I would say go for it. be sure to give it a real good check out before you fly it especially if it is a used plane.
My Alpha 40 has a .45 Evolution engine. It is pretty tough to find the actual displacement in the manual, and it's not marked on the engine anywhere that I could see.
It is a big engine. I have an OS LA .46 on another plane, and the Evo engine is a lot bigger in every way. The carb intake is almost twice as big, the cylinder head is way bigger, the muffler is bigger. I'm not sure why this is true. I am still training with mine, but I am having really good luck with it. I got it as a gift, but I think it is a great choice for a trainer. Make sure you check it out thoroughly if it's used. One thing I would check is if they epoxied the wing halves together, or just used the 1/2" tape per the instructions. I would also reinforce the firewall with tri-stock, as mine popped out once on a not-really-that-hard landing. Good luck. |
YOur .40 will be very adequate for the Alpha 40. I think they come with the .46 Evo's now, but a .40 is plenty.
1 Attachment(s)
the alpha 40 is a great plane...I stuck a Magnum 61 four stroke in mine for fun but a tree ate her about a month ago.....[&o]
No matter she served me well and you can only rebuild a plane so many times. |
ORIGINAL: mclina My Alpha 40 has a .45 Evolution engine. It is pretty tough to find the actual displacement in the manual, and it's not marked on the engine anywhere that I could see. It is a big engine. I have an OS LA .46 on another plane, and the Evo engine is a lot bigger in every way. The carb intake is almost twice as big, the cylinder head is way bigger, the muffler is bigger. I'm not sure why this is true. I am still training with mine, but I am having really good luck with it. I got it as a gift, but I think it is a great choice for a trainer. Make sure you check it out thoroughly if it's used. One thing I would check is if they epoxied the wing halves together, or just used the 1/2" tape per the instructions. I would also reinforce the firewall with tri-stock, as mine popped out once on a not-really-that-hard landing. Good luck. [link=http://www.rcuniverse.com/forum/m_4876737/mpage_1/key_hate%2Cmaiden/tm.htm]alpha .40 wing failure[/link] |
ORIGINAL: troposcuba ORIGINAL: mclina My Alpha 40 has a .45 Evolution engine. It is pretty tough to find the actual displacement in the manual, and it's not marked on the engine anywhere that I could see. It is a big engine. I have an OS LA .46 on another plane, and the Evo engine is a lot bigger in every way. The carb intake is almost twice as big, the cylinder head is way bigger, the muffler is bigger. I'm not sure why this is true. I am still training with mine, but I am having really good luck with it. I got it as a gift, but I think it is a great choice for a trainer. Make sure you check it out thoroughly if it's used. One thing I would check is if they epoxied the wing halves together, or just used the 1/2" tape per the instructions. I would also reinforce the firewall with tri-stock, as mine popped out once on a not-really-that-hard landing. Good luck. [link=http://www.rcuniverse.com/forum/m_4876737/mpage_1/key_hate%2Cmaiden/tm.htm]alpha .40 wing failure[/link] They also built some .46 engines http://www.horizonhobby.com/Products...rodID=EVOE0460 but NOT in the trainer series. The Alpha lists using the trainer system and the first one above is that trainer system. |
The biggest difference between a .40 ball bearing engine and a .46 ball bearing engine is usually in the mind of the person doing the purchasing...
bruce88123, thanks for the info. i was never sure what the evolution engine on it was. i know that it is a .040 size plane. wasn't really too familiar with what engines evolution offered. so that clears it up. thanks. like is said earlier, whatever it is, it runs dead rock solid without ever a hiccup. I think i have dead sticked that plane twice in the year i have owned it. once my fault for running out of gas, and the other was due to overlooking the fact i had a dying glow plug in it that would not have lasted another flight.
Alpha 9
Originally Posted by DoubleDD
(Post 6157519)
Yes the Hangar 9 Alpha 40 is a great trainer. I had two of them, one on wheels and the other on floats. I now have an Avistar Elite which is also a very good trainer. I just had the maiden flight less than a week ago. It flys very nicely.
Alpha 9
Easystar,
Funny thing, I also have a new Avistar. Waiting for maiden flight. I installed with flaps. Can't wait to try it. Take care. |
Originally Posted by Johnny Crash
(Post 12794923)
Easystar,
Alpha 9
Thanks Aiden. I can hardly wait to fly it. Best wishes.
