Servo reversing problems`
I just got my new futaba 6ex 2.4ghz, and i installed the reciever in my hanger nine twist, now since this is 6 channel i though it would be cool to program some elevon mixing, so i did as the book said and pluged my right airelon into channel 1 and left into channel 6, so i programed some elevon mixing and it worked great, but now i realized that my airelon was reversed so i went into the programing and reversed it, but now when i turn right both airelons go down and left both go up, i have read over the book several time and i just cannot figure out what i am doing wrong, Any suggestions are appreciated.
Thanks, Austin |
RE: Servo reversing problems`
Try reversing channel 1 only.
when you said reverse channel 1 only, i just realized that i have only been reversing channel one so i reversed both and problem solved, thanks, Now i can fly:D
No problem. Glad to hear it's fixed! [8D]
Computer radios can be confusing because not only do you have many mechanical adjustments, but you have a whole menu of adjustments you can make on the radio. It can really get confusing if you have a mechanical problem AND a radio setup problem. |
| All times are GMT -8. The time now is 06:39 AM. |
