glow size for parkflying?
What size glow engine/plane should I get if I want to use it for park flying? I have been doing electric and I hate the waiting in between flights. Plus when I occasionally go to fields it stinks to only get 1 to 2 flights it.
RE: glow size for parkflying?
You can't/shouldn't fly glow planes in the same airspace as a park flyer. You are going to need more room to fly a glow powered plane as they are usually bigger and faster than the park flyers you are now flying.
Ken |
Ken is right glow power and parks where dogs and people roam just won't make for a good mix in todays lawsuit happy world..You are a member of the AMA aren't you?
I live near a park with 4 baseball diamonds facing eachother in a big rectangle with no fences plus no one is on the field.
ORIGINAL: wws2010 I live near a park with 4 baseball diamonds facing eachother in a big rectangle with no fences plus no one is on the field. Ken |
So you are talking about 600 to 700 foot square?
Maybe something in the 1/2A size, check out the 1/2A forum. http://www.rcuniverse.com/forum/forumid_70/tt.htm The other thing is will the park allow you to fly glow engines there? |
Buy more batteries and a better charger.
ORIGINAL: RCKen ORIGINAL: wws2010 I live near a park with 4 baseball diamonds facing eachother in a big rectangle with no fences plus no one is on the field. Ken I've got an Ace Whizard lined up as a winter project. I was planning on flying it at the club fields, but hoped that it might be slow enough with a Thunder Tiger GP-07 to fly in smaller, convenient spaces. What is the minimum recommended flying area for an experienced pilot to fly a 1/2A trainer? http://www.acehobby.com/ace/images/a...ge/ACE4245.jpg |
my suggestion for size of a field is as follows: any club field will do..to risk injury while flying in a park is opening yourself up to big time trouble....even a small glow engine is spinning a prop with enough force to make serious cuts
ORIGINAL: jetmech05 my suggestion for size of a field is as follows: any club field will do..to risk injury while flying in a park is opening yourself up to big time trouble....even a small glow engine is spinning a prop with enough force to make serious cuts So I fly my Typhoon there and fly my nitro in a more controlled environment . |
A 1/2 A plane with something like a Cox .049 is almost the equivilent of a small electric but the noise might irritate people. I have a Cox .020 powered Pocket Rocket that could easily be flown in the confines of a schoolyard but is sounds like the world's most pissed off bumblebee.
Before electrics and "park flyers" there was 1/2A and "schoolyard flyers". |
| All times are GMT -8. The time now is 08:39 AM. |
