RE: DX7 - Help
The whole point of the voltwatch is to give a prudent pilot a view of what the voltage is at that time. If there is ANY question about the voltage, one or two things should be done. 1 is to check it with an ESV (Expanded Scale Voltmeter) which will test it under load. 2 is when in doubt, charge it.
A little common sense goes a long way with this stuff. |
RE: DX7 - Help
ORIGINAL: CGRetired The whole point of the voltwatch is to give a prudent pilot a view of what the voltage is at that time. If there is ANY question about the voltage, one or two things should be done. 1 is to check it with an ESV (Expanded Scale Voltmeter) which will test it under load. 2 is when in doubt, charge it. A little common sense goes a long way with this stuff. As someone else pointed out...this is a beginner's forum, let's not confuse them with "stuff" they really don't need. |
RE: DX7 - Help
First of all, I feel it is something that is useful even if you don't. And we are all entitled to our opinions. As for a beginners forum, well, where else would you suggest beginners learn about such items? In the Pattern forum?
| All times are GMT -8. The time now is 10:19 AM. |
