RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Saito 65 mounting question? HELP!!!!! (https://www.rcuniverse.com/forum/beginners-85/632116-saito-65-mounting-question-help.html)
lifesintheair 03-18-2003 12:47 PM
Can you mount a saito .65 black knight 4-stroke on a 45 degree or on its side or up side down? Does it have to be vertical because of the tube comming from the back?
Brian M.
MinnFlyer 03-18-2003 03:22 PM
You can mount it any way you like.
Buz^ 03-18-2003 03:29 PM
YEA WHAT HE SAID
The tube out the back is a vent/drain for crank case pressure/residue. Add a piece of fuel line just long enough to vent it out the bottom of your cowl, or the fuse. :D
