Old Expy
Well, I got the wing on my 4*60 (built upside down) apart, and after ten minutes with a heat gun pulled the shards of the dihedral brace out.
Doesn't look too bad. Anyway, there is old epoxy on the inside ribs. I tried scraping it off under heat and it worked ok, but how clean does it need to be? I'm going to insert a new rib-shaped "shim" between the wing halves to correct the dihedral angle and add a new brace before applying the fiberglass tape. Do I have to get down to bare wood or what? GB |
Old Expy
As long as it's relatively smooth, you should be ok.
Old Expy
You don't need bare wood. Covering (at least Ultracote) sticks pretty good on Epoxy and CyA.
| All times are GMT -8. The time now is 10:09 AM. |
