Receiver question... need answer FAST :)
Hey everyone,
Well I stripped down my 40 size World Hobbies Trainer today and I was wondering if I could use the RECEIVER with a new brushless or brushed ARF electric plane.... or will I have to buy a new receiver, I know all hte servos and everthing will work but I was wondering if I need a new receiver... also a ESC. Thank you ALL |
RE: Receiver question... need answer FAST :)
The reciever will be fine. You will need an ESC though for your motor eg: bruhless or brushed.
Get another opinion, but if it is a normal receiver and the cause of the crash was not loss of signal I belive i could use the some receiver.
If the receiver has another function like a gyro or a ESC integrated. In that case and if it works well you must know the power of motor and the ESC. |
thanks yall I'll go ahead and buy a new esc with the new plane I get then.... I did not even crash the plane apollo haha I Just stripped it down because I bought it off a guy for fifty dollars and it was just a beat up plane and the engine wouldn't start so I just took out all the electronics.. thank you though guys
Yes, use the same rx.
| All times are GMT -8. The time now is 10:56 PM. |
