RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   CG Eagle II build wing tips (https://www.rcuniverse.com/forum/beginners-85/6375584-cg-eagle-ii-build-wing-tips.html)
jeff1127 09-16-2007 04:38 PM
Ok ,
As the title says, I have a kit built Cal Goldberg EAGLE II and need to attach the plastic wing tips. My question is how do
cover, paint or otherwise continue the color scheme I already have? The wings are already covered and now I need to attach the tips.
Can I use the same Monokote or will the iron cause the wingtips to distort? Is paint an option and how can I get the best color match?
What glue is best to use? I have some canopy glue if that is good.
Can I cover then attach or should I glue and then cover?
Looking for any suggestions and Thanks in advance.
HollywoodHitman 09-16-2007 05:20 PM
RE: CG Eagle II build wing tips
All I did was glue them on the wing without covering them. They look fine in my books. But that being said, it's my first build, although guys at the field say I did a nice job. Depending on your color scheme, the might provide a good accent.
Cheers,
HH
2HI2C 09-16-2007 05:43 PM
Glue them on, Tape off so you won't overspray the wings, Most covering makers have paint to match.
hogflyer 09-16-2007 06:08 PM
Though I'm familiar with the material those tips are made from, generally with paint to match the covering you need to prime with a flat white primer before painting to get a good match. I've seen guys use red and gray primer and wonder why the color is darker than the covering. A good primer to use on plastic is the Tamyia flat white primer in the plastic model paints - it seems to be compatible with all the types of plastic used in plastic cars and planes. Use light mist coats since it's a lacquer based primer, but it covers great and leaves a fantastic base for paint. I use it exclusively now on my plastic models.
Hogflyer
jeff1127 09-16-2007 06:49 PM
Hogflyer,
I understand the use of different color primer coats affects the the final color of the topcoat. Lighter primers will produce a different shade on the topcoat than darker primers.It's all in the experimentation.
Will the iron used for Monokote soften or even melt the plastic wingtips?
2HI2C 09-16-2007 09:48 PM
Yes it will melt them.
sscherin 09-16-2007 10:35 PM
I just put them on plain white.
We used gorilla glue.. canopy glue would also work.
jeff1127 09-17-2007 09:17 AM
Thanks for all the responses. I'm going to go with the plain white for now.
KW_Counter 09-17-2007 02:29 PM
I left them off.
KW_Counter
