Pilot to plane orientation
I would like some ideas on how to keep my mental orientation coordinated with the planes controls when doing the inverted and incoming patterns. What techniques do you use?
RE: Pilot to plane orientation
1 Attachment(s)
When the plane is coming, you need to put the aileron stick to the dropped wing side to get it to fly leveled. Do this repeatedly and you'll end up not noticing if its coming or going in terms of what you have to do. The diagram explains better.
When inverted, the only thing that changes is the elevator which gets inverted no matter which way you're going. Ailerons remain exactly the same as with upright flight. Same coming towards you rule applies. |
When landing, a trick that works well is to face the runway and slightly turn your body away from the plane, then watch the plane over your shoulder. It sort of puts you in the pilots seat. Don't turn so far that it is difficlut to see the plane. It really helped me. I don't know if I still do it or not. I'll have to notice the next time I'm out.
Don |
Practice, practice, practice, and more practice. Lots of flying time, and if you've got a simulator, that will help tremendously with control perspective. Take your plane up high, practice what you need to work on, scare the $h!t out of yourself, fly some ovals and regain your nerves, and do it again. After awhile it will become automatic.
ORIGINAL: Jeffryz I would like some ideas on how to keep my mental orientation coordinated with the planes controls when doing the inverted and incoming patterns. What techniques do you use? There is only one way, PRACTICE. All the other techniques, only work because of PRACTICE. |
One thing simulators are good for ... testing things out and getting your orientation. :)
ORIGINAL: tIANci One thing simulators are good for ... testing things out and getting your orientation. :) And what are we doing when we use a simulator,,,,,,,, we are PRACTICING. I rest my case. |
yah, what they said
Practice, it is just a skill that comes with flight time. |
ORIGINAL: alan0899 There is only one way, PRACTICE. All the other techniques, only work because of PRACTICE. In all my years of flying and instructing I have heard of three methods of learning how to control and airplane that's coming toward you. I teach all three because what works for some people doesn't work for others and vice versa. Two of these methods have already been mentioned: 1 - Point the stick at the low wing 2 - Turn your back to the plane and look over your shoulder These two are by far the most popular. When I learned to fly (Yes, we had airplanes back then) I used method 2, but to each his own. A third method I have heard some people using is that they imagine themselves in the cockpit. I can't do this - in fact, most people can't do this, but for those who can, it works well, so I feel it's worth mentioning. But strongly consider the other two and use whichever one works best for you |
Here is what I teach:
1. On landing approach to level the wings push the aileron stick to the low wing. 2. When inverted the elevator is reversed. 3. For all other orientation upright or inverted do the following: Focus on the side of the plane closest to you. Think in terms of making the plane come toward you and away from you. If you are focused on the side of the plane closest to you, push the aileron stick toward the nose of the plane and the plane will come toward you. If you push the stick toward the tail the plane will go away from you. This works even if inverted. This is a very simple method of keeping your orientation. Do not think in terms of right and left. Think toward you and away from you. When the plane starts to fly toward you that means that the side of the wing farthest from you will come up. Hope this helps. bob |
ORIGINAL: alan0899 ORIGINAL: tIANci One thing simulators are good for ... testing things out and getting your orientation. :) And what are we doing when we use a simulator,,,,,,,, we are PRACTICING. I rest my case. Minn - I used the 'Point the Stick At' method when I learnt. That was a long time ago when JR just came out with dual rates. :) Did people wonder why you flew with your back to the plane ... heheheee ... A simple tip: For inverted flight I always roll my thumb to the back of the stick, that ensures that I cannot PULL the stick when you are trying to show off with a low inverted pass. :) |
I dunno. When I got the plane coming at me, I just usually crash, then go out and buy a new plane. Dr.1 |
Those are memory tricks to help you remember which way to pull the sticks in different orientations. Nothing wrong with starting with that, but it still takes lots of practice to have it come automatically to you. When you get into trouble (plane snaps out on you, cross wind flips you, etc.), panic ensues, and what's automatic to you will kick in. When I first started flying planes, I could tell you which way to pull the sticks in any orientation, IF I had 5 seconds to "put myself in the cockpit", and I wasn't flying at the time or scared $h!tless because I was about to crash.
ORIGINAL: Dr1Driver What techniques do you use? I dunno. When I got the plane coming at me, I just usually crash, then go out and buy a new plane. Dr.1 But not just when the plane is coming toward me :D |
Dr1 - do you own oil fields? :)
while flying inverted the ailerons aren't reversed so don't worry about that. however elevators are..simple rule never, ever loop out of inverted flight instead roll out. for minor pitch correction while inverted you're going to have to hold a bit of "down" elevator anyway let that be a reminder that down is up..if you get confused roll out and add power until you have yourself reset...,
And just for the record, rudder is reversed too
Do these rules apply to those from Australia? :)
I'm gonna be up all night contemplating that [sm=spinnyeyes.gif]
ORIGINAL: tIANci Do these rules apply to those from Australia? :) Ken |
When coming at you....the stick goes towards the low wing to pick it up. As you gain more experience...you wont even have to think about it. It becomes automatic.
I've been to the land down under, loved it there, friendliest people in the world. The blood didn't even rush to my head
ORIGINAL: RCKen ORIGINAL: tIANci Do these rules apply to those from Australia? :) Ken What ro347 says is very true ... |
Practise on the sim until it is second nature and you no longer have to think about orientation...
Then go fly and try the same at a good altitude. Worked for me... |
In my opinion looking over your shoulder is a crutch and does not teach you anything. After you have learned to land this way then you have to relean how to land facing the plane which means learning all over agian.
| All times are GMT -8. The time now is 05:48 AM. |
